Batch commands
Posted: 14 Nov 2011 16:38
Ive just started making use of the batch file feature in the Windriver program but am having a little problem LOading files larger than the internal memory.
I can load 00000-1FFFF#000000: fine but my next line (after sending to the pc) needs to be something like S4 LO 00000-1FFFF#020000:
is this possible using batch and if so what is the correct command for this action.
Also, is it possible to run an external application from within the batch file? Im pretty sure it isnt but it worth asking.
Thanks for you help
JonT
Thanks for you help
JonT
