New software - Version 3.41
Postby Dataman (Daniel Smith) » 22 May 2018 15:53
Adapter DIL48/QFP112 ZIF HCS12-3, updated SW interface
Added adapter: BGA-Bottom-360
Added adapter: BGA-Bottom-431
Added adapter: BGA-Top-363 ZIF-CS
Added adapter: BGA-Top-418 ZIF-CS
Added adapter: DIL48/LGA52-6 ZIF module 3D Plus NAND-1
Added adapter: DIL48/QFN32-1.02 ZIF MSP430-2
Added adapter: DIL48/QFN48 ZIF-CS nRF-1a
Added adapter: DIL48/QFN48-2.02 ZIF MAX-2
Added adapter: DIL48/QFN56-1.02 ZIF CHIL-3
Added adapter: DIL48/QFP100-1.02 ZIF-CS H8-4
Added adapter: DIL48/QFP44 ZIF Z8F-1
Adapter DIL24/QFN24-2.04 ZIF-CS EFM-2, insertion test bug fixed
Adapter DIL48/QFN20-1 ZIF-CS STM8-2, Automatic Yes! bug fixed
Adapter DIL48/QFP80 ZIF SiM-1, Automatic Yes! bug fixed
