New software - Version 2.34
Posted: 15 Nov 2011 09:57
New software has just been posted on our software pages for the Dataman 40Pro universal programmer.
Version 2.34 features the following amendments:
Many new devices have been added in this revision, please download the full device list to verify your chip is supported: http://www.dataman.com/Pdf/Dataman40ProDeviceList.pdf
Ali M6759 erase bug fixed
Atmel AT49BV802A/T insertion test bug fixed
Freescale MCHC908JW16 [LQFP48], correction of memory map
Fujitsu MB90F347 address pins mapping bug fixed
Motorola/Freescale MC68HC908AS60A [PLCC52] "SW internal error 1" fixed
NAND flash programming and verification routines improved
Spansion S29GL032MxxxxxR4 programming bug fixed
IC test bug fixed. The test was unsuccessful, if device with different organization than x8 was selected before
Dallas DS89C420 rev.A programming improved
Cypress CY8C26233 power-up sequence improved
EM Microelectronic EM4176, missed device identification added
IIC ISP devices added values of frequency 25kHz and 10kHz to the Device operation options window in part Clock signal frequency
Intel DT28F320S5 read/verify action improved
Microchip PIC16LF767 [QFN28] programming improved
Motorola/Freescale MC68HC711E9, 711E20, VDD current limit increased
Philips/NXP P89V51RB2/RC2/RD2 code improved
Samsung S3F9444 and S3F9454 programming procedure improved
Serial Flash ISP devices added value of frequency 2,5MHz to the Device operation options window in part Clock signal frequency
SST25xxx programming procedure improved
TI MSP430 series verify procedure improved
Xicor X84xxx devices added
NAND Flash Reserved Block Area method added for x8 NAND flash devices
