Adapter DIL48/QFP64-1.02 ZIF PIC-7, update of SW interface
Adapter DIL48/LQFP64 ZIF LM3S-1, Automatic Yes! bug fixed
New software - Version 3.47
Postby Dataman (Daniel Smith) » 08 Feb 2019 11:29
