New software - Version 3.48
Postby Dataman (Daniel Smith) » 08 Mar 2019 10:41
Added module: AP1 QFP48-1.02 ZIF IRMC-1
Added module: AP1 WLCSP62-1 ZIF nRF-3
Puya Semiconductor P25Q16H [SOP8-200], P25Q16H [SOP8-200] (Quad I/O), P25Q40UUX [USON8 2x3], P25Q40LUX [USON8 2x3], P25Q80LUX [USON8 2x3], added support
AP1 QFN8-5 ZIF SFlash-1, Automatic YES! problem fixed
