New software - Version 3.49
Posted: 16 Apr 2019 16:10
In PG4UWMC AP remote control mode is modified handling of multiply operations received from remote control application at the same time, to preserve currently running operations on Sites to display their operation results correctly
Added module: AP1 QFN24-1.02 ZIF CY-1
Added module: AP1 QFN32-1.02 ZIF EFM-4
Added module: AP1 QFP48-1.02 ZIF CY-1
Micron MT25QL256ABA8E12 [TBGA24] (Quad I/O), added support
