New software - Version 3.56
Posted: 04 Feb 2020 12:45
Actel/Microsemi A2F500M3G [FBGA484](STP), improving of overcurrent protection system
Added adapter: BGA-Top-402 ZIF
Added adapter: DIL48/PQFN24-2 ZIF CHIL-1
Added adapter: DIL48/QFN48-1.02 ZIF RTL-1
Added adapter: DIL48/QFN56-1.02 ZIF MAX-2
Added adapter: DIL48/QFN72-1.02 ZIF PLD-1
Added adapter: DIL48/WLCSP94-1 ZIF nRF-4
Atmel/Microchip ATSAM3X8CA [LQFP100], initialization procedure improved
Micron MT25QL128ABA1E [DFN8 8x6] (Quad I/O), MT25QL256ABA1E [DFN8 8x6] (Quad I/O), added support
Micron MT29F128G08AMAAAC5 [VLGA52], pins assignment fixed (was 2x CE# only)
Spansion/Cypress S6E1C1xD0AGV2 [LQFP64], S6E1C3xD0AGV2 [LQFP64], insertion test bug fixed
