USB driver stability improved
Adapter DIL48/SOIC20-300 ZIF AVR-1 renamed to DIL48/SOIC20-300 ZIF AVR-3
Adapter DIL48/QFP32-1.04 ZIF AVR-1 renamed to DIL48/QFP32-1.04 ZIF AVR-4
Adapter DIL48/QFN32-1.02 ZIF AVR-2 renamed to DIL48/QFN32-1.02 ZIF AVR-4
Added adapter: BGA-Bottom-473 + BGA-Top-437 ZIF
Added adapter: DIL48/QFP112-1.03 ZIF R5F-1
Added adapter: DIL48/QFP128-1.01 ZIF ITE-1
Added adapter: DIL48/QFP48-1.02 ZIF R5F-10
Added adapter: DIL48/QFP64 ZIF STM32G4-1
Added adapter: DIL8W/TSSOP8 ZIF 170mil SFlash-1b
Atmel/Microchip ATmega640/1280/2560 [CBGA100], added acceptance of BGA-top-117
Fixed bug "Unexpected error 1" related to operations with adapter DIL48/QFP80 ZIF HCS12-1
STMicroelectronics STM32F412RxY [WLCSP64], message "Bad contact at pin(s) -8,-7,-5,-4,-3,-2,-1,.. of ZIF socket of programmer." fixed (in case of empty ZIF on DIL48/WLCSP64-3 ZIF STM32-3 adapter)
New software - Version 3.60
Postby Dataman (Daniel Smith) » 30 Jun 2020 14:39
