Added module: AP1 QFN11-1 ZIF
Added module: AP1 QFN24-1.02 ZIF AUO-1
Added module: AP1 QFN28-1 ZIF
Added module: AP1 QFN40-2.02 ZIF TPS53-4
Added module: AP1 QFN48-1.02 ZIF EZR-1
Added module: AP1 QFN48-1.02 ZIF TLSR-1
Added module: AP1 QFN48-2.02 ZIF ISL-2
Added module: AP1 QFN56-1.02 ZIF CHIL-2
Added module: AP1 QFP64 ZIF FM3-1
Atmel/Microchip ATtinyxx2/xx4/xx6/xx7 (ISP-UPDI), added support
Module AP1 QFP48 ZIF STM32-3 set as a replacement for module AP1 QFP48 ZIF STM32-2 and an alternative for module AP1 QFP48 ZIF STM32
Module AP1 TQFP64 ZIF AVRmega-2, update of SW interface
Renesas R5F1026Ax (ISP), added support
New software - Version 3.61
