Is it possible to expand the list of ics that the application remembers to more than 20 that are currently saved. Something around 100 would be much better as i use lots of different ics and some settings drop off the list often and i have to keep a separate list of the options for each.
If the remembered list was bigger this wouldn't be so much of a problem.
Thanks
Jim
Expand defined/remembered list of selected ics
Re: Expand defined/remembered list of selected ics
Hello Jim,
Have you tried saving a project file for each chip? This will contain the device selection, settings and buffer data. You can then simply double click on a project file at a later date which will launch the programmer software with the correct chip selected, load the correct settings and data into the buffer ready to program.
If you have any further questions then please let me know.
