New software - Version 3.67
Postby Dataman (Daniel Smith) » 30 Apr 2021 14:28
Added module: AP1 BGA64-1.2 ZIF NOR-1 (LD)
Added module: AP1 QFN36-1.02 ZIF ZL-3
Added module: AP1 QFP100 ZIF NEC-8
Added module: AP1 QFP100-1.02 ZIF MN1-1 (RD)
Added module: AP1 QFP48-1.02 ZIF R5F-3
Added module: AP1 QFP80-1.02 ZIF RX-2
Module AP1 QFP64 ZIF MC9S-2, insertion test bug fixed
