trying to access a intel ab28f200-b is there an ISP option??
tomanycars
Postby tomanycars » 30 Jun 2021 09:39
Hi
I have a ab28f200-b flash that i need to access for a job , is there an option for ISP , or a dip breaking out option for ZIF connection. unfortunately i am unable to remove it from the target from the host board as it'll destroy the board is this this the only option?
thanks
Adam
Re: trying to access a intel ab28f200-b is there an ISP option??
Postby Dataman (Neil Parker) » 30 Jun 2021 09:56
Hello Adam,
The Intel AB28F200 is a parallel FLASH memory so cannot be programming using ISP which is serial based. In order to read or write this device it must be removed from the PCB (cleaned of solder/flex residue) and placed directly into the adaptor socket connected to the programmers ZIF.
Extending the signals from the programmers ZIF is not recommended or supported by Dataman, it will almost certainly give disappointing results.
tomanycars
Postby tomanycars » 30 Jun 2021 09:59
hi Neil
I appreciate the swift reply. I was hopping it wasn't the case , I'll have to check my other options i have available for this particular job.
id10t_fix_
Postby id10t_fix_ » 04 Sep 2026 14:35
Which dataman ZIF adapter do I need to use for programming the ab28f200-b?
I have the 48pro 2 programmer
Is it the LP48-PSOP-44PIN(1208)?
I want to make sure I get the correct adaptor.
Thank you
Postby Dataman (Neil Parker) » 04 Sep 2026 15:53
Hello id10t_fix_,
The AB28F200B device in PSOP44 package requires the Bottom PSOP44 NOR-1 + Top PSOP44 ZIF 600mil socket combination.
For future reference there is an adaptor selection guide on each adaptor page: https://uk.dataman.com/adapters/adapter ... ide-1.html
