New software - Version 3.75
Posted: 25 Mar 2022 11:46
Version 3.75 features the following amendments:
PG4UW, PG4UWMC, Load, Save dialogs, added dialog last position saving
PG4UWMC HW USB interface, SITE CLEAR signal when site not busy - processing fixed
Adapter DIL48/BGA137-1 ZIF NAND-1 allowed as an alternative for BGA-Bottom-166 + BGA-Top-206 ZIF-CS
Added adapter: BGA-Bottom-546
Added adapter: BGA-Top-484 ZIF-CS
Added adapter: DIL48/QFN48-1.02 ZIF ARM-6
Added adapter: DIL48/QFN48-2.02 ZIF ISL-3
Added adapter: DIL48/QFN48-2.02 ZIF TPS-2
Added adapter: DIL48/QFN52-2.02 LT-1
Added adapter: DIL48/QFP48-1.02 ZIF STM32G4-1
Added adapter: DIL48/QFP52-2.03 ZIF-CS SRAM-1
Added adapter: DIL48/QFP64-1.02 ZIF R5F-20
Added adapter: DIL48/WLCSP75-1 ZIF nRF-4
Added adapter: DIL8/BGA8-11 ZIF-CS
Fujitsu/Spansion/Cypress MB9B110T/210T/310T/410T/510T/610T series in LQFP176, insertion test improved
GigaDevice GD25Q80C, setting Protected memory modified
Infineon XDPE12284C [QFN40] (Single Config.), programming procedure improved
Macronix MX25L3233F [USON8 4x3], MX25L3233F [USON8 4x3] (Quad I/O), added adapter DIL8/QFN8-9 ZIF SFlash-1b
Macronix MX25V1606F [SOP8-200] (Dual O), added support
Microchip dsPIC33EP256MU810, added option to switch between the ICSP/EICSP modes
Microchip PIC16F184xx, programming EEPROM algorithm modified
Micron MT35XU02GCBA1G12, insertion test modified
Motorola/Freescale Semic. MC68HC705X32 [QFP64], separated EEPROM programming option added
MPS MP297x, improved of decoding *.txt file
NXP LPC55xx, reliability of communication improved
NXP PN7462xxx, programming procedure improved
Renesas/IDT 5P49V5901B000, add of programming Trim with values according *.tcs file
Renesas/IDT 5P49V5901B000, add of VCO calibration
Renesas/Intersil/Zilker Labs ZL2xxx, improving of ID check routine
Samsung KLMBG2JETD-B041 [FBGA153], added support PRV 0.8
Semtech LR1110, reliability initialization of device in modem implementation improved
Serial Flash devices in package USON8 4x3/UFDFPN8 4x3/QFN8 4x3, added DIL8/QFN8-9 ZIF SFlash-1b adapter
STMicroelectronics M24M01-R, add options Empty check before programming
STMicroelectronics STM32H7xx, algorithms modified due to added OTP memory support
TI (TMS) MSP430FR58xx/FR59xx/FR6xx, added testing IP Encapsulation Signatures
Toshiba TMPM370FYFG (ISP-UART), speed of verification operation improved
Adapter DIL48/QFN36 ZIF-CS ZL-1, insertion test bug fixed
Atmel/Microchip ATSAM4S2xx, verification procedure Lock Bits fixed
Freescale Semic., NXP MC9S08Axxx [LQFP44], insertion test bug fixed
Microchip AVR DA family, Unable to enter programming mode when RSTPINCFG fuse set to RESET bug fixed
Microchip AVR DA family in QFN32 package, Unexpected error bug fixed
Micronas HAL3930, HAL3900, verify error if MSb on address $5A in buffer is 1(lock bit set) bug fixed
NXP LPC11E37 (ISP-SWD), programming procedure bug fixed
Silicon Laborat. EFR32xG12xxx devices, Lock Bits Page programming bug fixed
STMicroelectronics M24M02, reading procedure bug fixed
STMicroelectronics STM32H7A3ZIT [LQFP144], OTPBL read/verify bug fixed
