New software - Version 3.77
Posted: 14 Jun 2022 10:16
Version 3.77 features the following amendments:
Fixed CRC-CCITT and CRC-XMODEM checksum calculation
PG4UW: General Options/Job Report, changed checksum type used in file name
PG4UWMC: General Options/Job Report, file name generation options extended
Added adapter: BGA-Bottom-434
Added adapter: DIL40/SSOP20-200 ZIF AS5-1
Added adapter: DIL48/BGA98-1 ZIF LPC-1
Added adapter: DIL48/LGA108-1 ZIF LTM-3
Added adapter: DIL48/module ZIF-CS MS88SF2
Added adapter: DIL48/QFN48-4.02 ZIF LT-1
Added adapter: DIL48/QFN60-1.02 ZIF ISL-1
Added adapter: DIL48/QFP100-1.02 ZIF A34-1
Added adapter: DIL48/QFP100-1.02 ZIF STM32G-1
Added adapter: DIL48/QFP128-1.01 ZIF ARM-1
Added adapter: DIL48/QFP48-1.02 ZIF LPC-5
Added adapter: DIL48/QFP64-1.04 ZIF R5F-19
Anlogic SALELF2 Erase+SVF, improving of erase action for devices with specific initial content
Atmel AT90S/LS4434 [PLCC44], insertion test modified
Atmel AT90S/LS4434 [TQFP44], AT90S/LS8535 [TQFP44], AT90S/LS2333/4433 [TQFP32], added new programming adapter option, insertion test modified
Atmel ATmega163 [TQFP44], added new programming adapter option, insertion test modified
Atmel ATmega323 [TQFP44], insertion test modified
Atmel/Microchip ATmega16/32 [TQFP44], insertion test modified
Atmel/Microchip ATtiny2313/4313, Device info updated
Boya Micro BY25D40A, setting Protected memory modified
cFeon(Eon Si.Sol.) EN25E40A(2A), setting Protected memory modified
Eon Silicon Sol. EN25E40A(2A), setting Protected memory modified
ESMT EN25E40A(2A), setting Protected memory modified
First-Rank Techn. T25S40-PB, setting Protected memory modified
GigaDevice GD55LB02GE, GD55B02GE, GD55X02GE, GD55LX01GE, GD55LB01GE, GD55T01GE, GD55X01GE, GD55B01GE, GD55B512MEFxR, GD25F256F, GD25Q256E, GD25Q256D, GD25LX256E, GD25LB256E, GD25LF255E, GD25LE255E, GD25Q257D, GD25LT256E, GD25Q256C, GD25B256D, GD25S513MD, GD25Q41B, GD25VQ41B, GD25WD10C, GD25D10B, GD25D10C, setting Protected memory modified
Microchip/Atmel ATF16V8C, ATF16LV8C, improving of read routine with possible impact to a device ID code
Mitsubishi/Renesas M38039FF (ISP-SCI), power-up and device info modified
Samsung KLMBG2JETD-B041 [FBGA153], added support PRV 0.3
Samsung KLMxGxJETD-B041 [FBGA153], stability of reading/verifying device improved
Silicon Laborat. MGM210P module, Device info modified
Silicon Works SW31100 [LQFP64], test ECC flags added
Winbond W25Q16FWxxxQ, Alt+S menu improved, LBO bit removed
Wisekey, InsideSecure AT90SCR100LSD/200LSD [QFN32], package drawing updated
XMC XM25QU256B, XM25QH256B, setting Protected memory modified
Zetta ZD25Q16B, ZD25WD40B, setting Protected memory modified
Adapter DIL48/QFP176-1 ZIF TMS320-2a, Automatic YES! bug fixed
Adapter DIL48/TSSOP16-170 ZIF R5F-2, Automatic YES! bug fixed
Adapter DIL8/BGA24-2 ZIF SFlash-1b, interface bug fixed
Infineon XDPE12284C [QFN40] (Single Config.), LAN communication error bug fixed
Lattice LAXP2-5E/8E [csBGA132], LAXP2-5E/8E/17E [ftBGA256], pgm adapter assignment bug fixed
Microchip SST26WF064C [SOIC16] (QuadSPI), pinout bug fixed
Micronas HAR3735/3736, Miscalculation when entering CLAMP LOW hex register higher then 7FFFh bug fixed
Mitsubishi/Renesas M38039FF (ISP-SCI), communication speed setting bug fixed
NAND flash devices, binary file load, fixed file size/start/end values display
Winbond W25Q256JVxxQ [SOIC16] (QuadSPI), W25Q256JVxxM-DTR [SOIC16], W25Q256JVxxM-DTR [SOIC16] (QuadSPI), W25Q256JVxxM [SOIC16], W25Q256JVxxM [SOIC16] (QuadSPI), pinout bug fixed
