Is ATMEL ATF2500C fully supported on 48UXP?
Posted: 11 Sep 2022 10:05
Hi Dataman,
Looking to make use of ATMEL ATF2500C CPLD. In the version 13 device list, I notice that ATF2500C is not listed but that its earlier versions ATV2500B/BQ/BQL/H/L are. From reading the datasheet it seems to me that if I program the ATF2500C as one of the earlier versions I lose the pin-keeper function and access to the user fuses. Am I reading that right? Is it possible to add direct ATF2500C support in a future update to the 48UXP software?
A similar situation exists for the ATF750C (which I also use). But in that case, the ATF750C is directly supported by the 48UXP software, as is its ATV750 predecessors.
Thank you,
William (Billy) Crowson
Thank you,
