New software - Version 3.81
Postby Dataman (Daniel Smith) » 25 Nov 2022 16:20
Added adapter: BGA-Bottom-527
Added adapter: BGA-Top-153 ZIF-CS
Added adapter: DIL48/QFN32-1.02 ZIF FL-1
Added adapter: DIL48/QFN32-1.02 ZIF PLD-4
Added adapter: DIL48/QFN32-1.02 ZIF R9A-1
Added adapter: DIL48/QFN48-1.02 ZIF NUC-3
Added adapter: DIL48/QFN48-1.02 ZIF PLD-6
Added adapter: DIL48/QFN64-1.02 ZIF PIC-4
Added adapter: DIL48/QFN68-1.02 ZIF ISL-2
Added adapter: DIL48/QFP100-1.02 ZIF PLD-31
Added adapter: DIL48/QFP144-1.02 ZIF SH-3
Added adapter: DIL48/TSSOP20-170 ZIF APM32F00-1
eMMC devices, added adapter DIL48/BGA153-1.01 ZIF eMMC-3
eMMC devices, register value "Write Counter" added into log window
Gowin Semicond. GW1N-UV4 [LQFP144], usercode programming improved
Gowin Semicond. GW1N-LV4 [LQFP144], GW1N-UV4 [LQFP144], corected device name, package name to LQ144
Intel/Altera 5M1270Z [FBGA324], improving of overcurrent protection system
Intel/Numonyx/Micron PC28F128J3F [Easy BGA64], read of Protection register improved
Intel/Numonyx/Micron PC28F128J3F [Easy BGA64], verification of Protection register improved
Microchip ATF1504ASV [TQFP44], pgm parameter assignment bug improved, Unexpected error 1 [IEC:1, D:1D]! fixed
NXP LPC55S69 [HTQFP64], incorrect size of device fixed
TI (TMS) LMK03328 [WQFN48], Unexpected error 1 [IEC:1, D:1A] bug fixed
