New software - Version 3.81
Posted: 25 Nov 2022 16:22
Version 3.81 features the following amendments:
General Options/File Load, added functionality "Calculate checksum of file to be loaded before processing"
mDOC H3 devices, fixed PG4UW software exception "Access violation" bug if the image file is larger than 2GB
Writing of erase value of buffer block operations in log fixed
Added module: AP1 QFN28-8.02 ZIF STM32G-1
Added module: AP1 QFP144 ZIF PLD-6
Added module: AP1 QFP48 ZIF STM32G-1
Added module: AP1 QFP64-1.02 ZIF R5F-14 (LD)
Added support for Infineon 8-bit F2MC New 8FX family CY95Fxxx devices (ex Cypress/Spansion)
Added support for Infineon FM3 32-bit Arm Cortex-M3 devices (ex Cypress/Spansion)
Added support for Infineon FM4 32-bit Arm Cortex-M4 devices (ex Cypress/Spansion)
Added support for Infineon FM0+ 32-bit Arm Cortex-M0+ devices (ex Cypress/Spansion)
Analog Devices ADUC7023xxxxx62I [LFCSP32], Added reading procedure
Atmel/Microchip AT89C5131, Setting Extra Row modified
Atmel/Microchip ATtiny406/806/1606 [VQFN20], added new programming adapter option
Atmel/Microchip ATtiny416/816/1616/3216 [VQFN20], added new programming adapter option
Cypress CY8C6 family, reliability of communication improved
eMMC devices, register value "Write Counter" added into log window
GigaDevice GD25Q32C, GD25Q64C, setting Protected memory modified
Gowin Semicond. GW1N-UV4 [LQFP144], usercode programming improved
Gowin Semicond. GW1N-LV4 [LQFP144], GW1N-UV4 [LQFP144], corected device name, package name to LQ144
Gowin Semicond. LittleBee family, pgm parameters assignment improved
Gowin Semicond. LittleBee family, added device versions
Gowin Semicond. LittleBee and Arora families, added binary file format support
Intel/Altera 5M1270Z [FBGA324], improving of overcurrent protection system
Intel/Numonyx/Micron PC28F128J3F [Easy BGA64], read of Protection register improved
Intel/Numonyx/Micron PC28F128J3F [Easy BGA64], verification of Protection register improved
Macronix MX25UM51245GXDx00 [BGA24] (Octa I/O), added support
Microchip ATtiny426/826/1626 [VQFN20], added new programming adapter option
Microchip dsPIC33CH256MP505, programming/verification procedure improved
Microchip dsPIC33CH256MP505, load hex file and FCFGPRB0 bits in the Alt+S menu improved
Microchip PIC24FJ128GB106, programming procedure for Configuration words improved
Microchip PIC32MZ EF Family, default adresses for configuration bits improved
Module AP1 BGA24-2 ZIF SFlash-1b enabled as an alternative for all serial Flash
Module AP1 QFN8-4 ZIF SFlash-1, insertion test improved
NAND flash devices, "User Data with IB Info Forced" spare area usage mode supressed for OTP area (User Data mode used instead)
Renesas R5F566Txxxxx, buffer size modified
Renesas R5F5630DxxFB, device info modified
Renesas/Mitsubishi M30845FJGP, programming Boot ROM modified
STMicroelectronics STM32G031GxU [UFQFPN28], STM32G071GxU [UFQFPN28], STM32G081GBU [UFQFPN28], added support
STMicroelectronics STM32G030CxT [LQFP48], STM32G070CBT [LQFP48], STM32G071CxT [LQFP48], STM32G0B0CET [LQFP48], STM32G0B1CCT [LQFP48], added support
STMicroelectronics STM32G0xx devices, algorithms modifified
STMicroelectronics STM32H723xx and STM32H733xx ISP devices blank check speed improvement
STMicroelectronics STM32L4 Series, programming method changed (introduced modes program all data, only data from file, only nonblank data; discarded mode program selected pages)
Winbond W25Q01JVxxxQ, default value DRV0, DRV1 bits of Status register changed
Winbond W25Q128JVxxM-DTR [SOIC8-200] (QuadSPI), verification procedure improved
XTX XT25F16B, added QE Bit programming
Atmel/Microchip AT90PWM316 [QFN32], device info corrected. Flash and EEPROM size and addresses corrected.
Microchip ATF1504ASV [TQFP44], pgm parameter assignment bug improved, Unexpected error 1 [IEC:1, D:1D]! fixed
Motorola, Freescale MC908AS60, EENVRx programming bug fixed
Nuvoton W78E516D, Security register programming bug fixed
NXP LPC55S69 [HTQFP64], incorrect size of device fixed
NXP PD692xx, communication timeout during PGM fixed
STMicroelectronics STM32G0x1 devices, FLASH_SECR bug fixed
TI (TMS) LMK03328 [WQFN48], Unexpected error 1 [IEC:1, D:1A] bug fixed
TI (TMS) TPS53685, TPC536C5, insertion test bug fixed
TI (TMS) TPS53689, TPS536C9 - info about supported programming file bug fixed
Winbond W25N serial NAND, block protection check problem on Blank operation fixed
