Charging from a bench supply
adriangodwin
Postby adriangodwin » 22 Jan 2023 11:26
I am charging the S4 from a bench supply (cautiously, as advised).
It charges OK, but the INFO function says CHARGER DISCONNECTED OR SUPPLY OFF
Is this normal when the proper AC adapter isn't used ? If so, what does it take to detect a connected charger ?
Re: Charging from a bench supply
Postby Dataman (Neil Parker) » 23 Jan 2023 09:47
Hello adriangodwin,
The S4 will only detect that the charger is connected if it is supplied with A/C current, as with the original S4 charger.
If there is anything else I can help you with, please let me know.
adriangodwin
Postby adriangodwin » 15 Feb 2023 00:09
With an AC supply it worked correctly. Thanks !
Return to “Dataman S4”
