New software - Version 2.71
Posted: 15 Nov 2011 12:45
Freescale Semic. MCF5216, programming algorithm bug fixed
Spansion S29GL256PxxTxx02, fixed bug on checking socket converter
Winbond W39Vxxx, programming bug fixed
Macronix MX29SLxxx, programming time improved
