New software - Version 3.85
Posted: 04 May 2023 10:57
Added module: AP1 BGA64-2.3 ZIF NOR-4
Module AP1 QFN28-2 ZIF STM32-3&GD32, support fixed (ZIF force added)
Microchip PIC18F26Q10 [VQFN28], added support
MT25QU512ABB8E12 [TBGA24] (Quad I/O), added support
