PG4UWMC: fixed PG4UWMC software bug for option "Network mode" for stand-alone programmer
Added adapter: BGA-Bottom-556
Added adapter: BGA-Top-384a ZIF
Added adapter: DIL48/BGA121-5 ZIF NAND-1
Added adapter: DIL48/BGA40-AM30LV ZIF-CS NAND-1
Added adapter: DIL48/BGA48-10 ZIF nvSRAM-1
Added adapter: DIL48/QFN35 ZIF TPS-2
Added adapter: DIL48/QFP64-1.02 ZIF APM32-1
Added adapter: DIL48/QFP64-1.02 ZIF CY-4
Added adapter: DIL48/QFP64-1.02 ZIF R5F-8
Added adapter: DIL48/WLCSP144-1 ZIF STM32-1
DIL48/QFP100-1 ZIF HCS08-1, adapter interface bug fixed
New software - Version 3.85
