New software - Version 2.74
Postby Dataman (Daniel Smith) » 15 Nov 2011 12:47
Fixed bug in Automatic YES!
Realtek RTD2120L, power-up modified
Renesas Technology R5F21255SNFP [LQFP52](UART), power-up modified
Macronix MX29LV320MH [TSOP56] x16, Unexpected error 1 [IEC:1, D:0F] fixed
