New in Pg4uwMC - improved function of "Search for programmers" to enable search for and use of multiple programmers together
Atmel ATxmega32D4P, ID fixed
New software - Version 2.78
Postby Dataman (Daniel Smith) » 15 Nov 2011 12:49
