New software - Version 3.11
Posted: 20 Jan 2015 21:25
Version 3.11 features the following amendments:
Information about last selected action on device in job report modified
Fixed hazard for slow PC in Automatic YES! setting's wizard
Fixed randomly occurred bug when accessing identification chip of programming adapters
Former Selftest and Selftest plus functions were merged to one new complex Selftest function
Modification for ZIF socket actuation unit, switching off driver when servo is not active
Actel/Microsemi ISP devices, added options to test programmed chip supply voltage from 1800mV
Added support of DIL48/BGA80-1.1 ZIF NOR-1
Analog Devices ADUC7022x, programming improved
Analog Devices ADUC7022xxxx62, programming algorithm improved
Atmel ATmega324P-B [MLF44], Extended fuse byte default value changed
Atmel ATSAMD20xx, Lock bits and Security bit in Special options added
Atmel ATtiny441/841, Extended fuse options in "View/Edit Lock, Fuses and Calibration" win.(ALT+S) modified
Atmel ATtiny441 [SOIC14], Device renamed to ATtiny441 [SOIC14](HVSP)
Atmel ATtiny841 [SOIC14], Device renamed to ATtiny841 [SOIC14](HVSP)
BGA-Bottom-255 + BGA-Top-148 ZIF, improving of pgm parameter assignment
Cypress CY8C20337 [QFN24] insertion test modified
DIL48/QFP80 ZIF C8051-1, adapter identification improved
Disable menu item "Select EPROM/Flash by ID" if ISP device is selected
eMMC devices, insertion test improved
Energy Micro/Silicon Laborat. EFM32G230F128 [QFN64], power-up sequence modified
Exar XRP7724, programming procedure improved
Freescale Semic. MC9S12DG128 [QFP80], improved detection of Secured device
GreenPeak devices, added extended logging option
Infineon TLE9832QX/QV (LINBSL), erase procedure modified
Microchip dsPIC33EPxxxMCxxx, dsPIC33EPxxxGPxxx, PIC24EPxxxMCxxx, PIC24EPxxxGPxxx, configuration bit mask improved during verification operation
Microchip dsPIC30F5011, programming algorithm improved
Micron M28W320FCBxxZB [TFBGA47], power-up sequence modified
Micron N25Q512Ax1G, changed device name and backward project compatibility correction
Micron N25Q512Ax3G, changed device name and backward project compatibility correction
Nordic nRF51422, nRF51822, changed device name (added suffix)
Renesas R5F52108xxFN, programming modified
Silicon Laborat. C8051Txxx, added feature of marginal verify
Spansion S29GL128PxxTxxV2 [TSOP56]x16, power-up sequence modified
STMicroelectronics STM32L1xx, option bytes modified according to new reference manual
STMicroelectronics ST7FLITEU0xM, information about required programming adapter improved
TI (TMS) MSP430F52xx, programming algorithm improved
TI (TMS) TM4C, LM4F family, programming algorithm improved
Toshiba TMP86FS49BFG (ISP), programming and erase procedure modified
Xilinx XC3S200AN [FTBGA256], modified testing of programming adapter
Atmel ATSAMD20xxxx, erase operation unlocks all flash regions, programming Security bit fixed
DIL48/QFP144 ZIF STM32-2, programming adapter test error fixed
Freescale Semic. MPC5517S [LQFP176], "no verify operation selected" error bug fixed
GigaDevice GD25xxxx with security sectors, verifying bug fixed
NEC/Renesas uPD78F0711/0712, verification procedure bug fixed
Numonyx M58WR032KT [VFBGA56], algorithm bug fixed
Micron MT29F8G16ABACAWP-IT [TSOP48], insertion test bug fixed
Panasonic MN103SFC2D [QFP44], verification bug of DATA area fixed
Renesas R5F2M110AxSP [TSSOP14], device settings bug fixed
Renesas uPD70F3526, AutomaticYes bug fixed
Samsung KLM4G2DEHE-B101 [FBGA153] (unvfy), bug fixed
STMicroelectronics STM32F2xx, STM32F4xx, 64-bit programming mode fixed
