New software - Version 3.12
Posted: 23 Feb 2015 15:54
Version 3.12 features the following amendments:
Checksum calculation modification in dialog "Checksum calculator" for devices with 14 bit data organization (for example Microchip PIC16F1503 devices)
Improved recovery of corrupted programming adapter ID chip memory
Fixed bug in selftest (range check error) for some programmers
Fixed permanently disabled View/Edit buffer menu in Protected mode, when the menu should be enabled by related settings of Protected mode
Added support of AP1 BGA-0395/0259 module
Added support of AP1 QFP100 ZIF PLD-7 module
Added support of AP1 TSOP56 ZIF 18.4mm NOR-5 module
Added support of AP1 TSOP56 ZIF 18.4mm NOR-9 module
Analog Devices ADUCM36x, programming algorithm improved
Atmel AT91SAM7X512B, added new ID code
Atmel ATA6616C/6617C, package drawing updated
Atmel ATtiny441/841 [MLF20], device renamed to ATtiny441/841 [MLF20](HVSP)
Atmel ATtiny441/841 [VQFN20], device renamed to ATtiny441/841 [VQFN20](HVSP)
Atmel ATxmega A4/U/C4/D4/P series in QFN package, package drawing updated
Azoteq IQS228AS, programming procedure improved
Dallas/Maxim Devices in TSOC6 package, programming adapter changed
eMMC devices, added support for SECURE_REMOVAL_TYPE
eMMC devices, programming Extended CSD register improved
Explore Microelec. EPF011A [QFP64], insertion test modified
Freescale Semic. MC68HC908RF2 [LQFP32], read/unlock secured device note to device info added
Intel TB28F200BX-T [PSOP44], read procedure improvement
Silicon Laborat. C8051F98x/99x, power-up sequence modified
STMicroelectronics M48Z35, improved power-down sequence
STMicroelectronics STM8S103F3P [TSSOP20], power-up improved
Atmel ATSAM3S/4Sxxx, EDevOpt Fatal Error fixed
Dallas/Maxim DS28E02, programming of READ/WRITE protection of page 3 bug fixed
eMMC devices, programming Extended CSD bug fixed
Fudan Microelect. FM24C02C (ISP), device size fixed
GigaDevice GD25Q256C, programming bug fixed
Microchip dsPIC30F6010/6014, programming procedure bug fixed
Microchip PIC16LC554, Access Violation bug fixed
Microchip PIC24EP128GP204, buffer size bug fixed
Nand flash devices, unwanted pointers reset after operation is finished fixed
Raydium RM24C02 (ISP), device size fixed
Renesas R5F10x Family, Get/Set security procedure bug fixed
Renesas uPD70F3532, AutomaticYes bug fixed
STMicroelectronics STM32F4 devices in WLCSP143 package, programming adapter assignment fixed
STMicroelectronics STM32L1 devices in WLCSP104 package, programming adapter assignment fixed
STMicroelectronics STM8S005K6T [LQFP32], verify option bytes bug fixed
