DIL48/LQFP32 ZIF Kinetis-1 adapter, added support
DIL48/LQFP64 ZIF MC56F-1 adapter, added support
DIL48/QFP128 ZIF-CS HD64-3 adapter, added support
DIL32/TSOP32 ZIF 12.4mm NOR-1 adapter, added support
Silicon Laborat. EFM8SB2xxx, operation stability with Scratchpad Flash improved
Fujitsu MB85R4001A, bug fixed
New software - Version 3.17
