New software - Version 3.17
Posted: 02 Sep 2015 16:08
Intel/Numonyx/Micron PC28F00AM29EWH [BGA64], added support
Intel/Numonyx/Micron PC28F00AM29EWL [BGA64], added support
Fujitsu MB85R4001A, bug fixed
