can you remove the battery
Topics related to the Dataman S3
zarniwooop
Postby zarniwooop » 03 Mar 2025 08:54
Hi there.
My Dataman S3 battery is dead.
can i remove the battery and use it using the original charger/psu.
sorry if this has been asked before.
i did a quick search but could only find posts on replacing batteries not removing.
Re: can you remove the battery
Postby Dataman (Neil Parker) » 03 Mar 2025 09:47
Hello zarniwooop,
If you must remove the S3 nicad pack, then the best option is to connect a DC bench supply directly into the battery connector. Set the bench supply to 9V and the S3 should power up allowing you to load a HELP ROM and use it.
zarniwooop
Postby zarniwooop » 03 Mar 2025 10:06
Thanks
Return to “Dataman S3”
