Hello,
There are few questions:
1. What is the difference between "Registers" checked or not checked?
2. Understood, if the QE is enabled, !WP and !HOLD functions are disabled. How to re-verify the memory after programming?
3. For QE enabled, can we program the main content first, verify and then program the "Special options"? if yes how to do it?
4. Are there any ways to read the IC with QE enabled?
Thank you very much!
ISP programming
Re: ISP programming
Hello KYPeter-Lee,
It is the same as the "Flash" checkbox or the other checkboxes. Checked = program this area, unchecked = don't program this area.
The device starts in single SPI mode. So you can simply perform the Verify operation.
Yes, you can. In the "Programming parameters", check the Flash and Registers checkboxes and in the "Special Options" set the QE as Enabled = 1.
Yes, there are. Just perform a read operation on the device.
