New software - Version 4.04
Posted: 14 Jul 2025 16:21
Version 4.04 features the following amendments:
Job Report formatting modified in PG4UWMC
PG4UW: fixed PG4UW software exception "Error occurred during deallocating program environment." bug
PG4UW: View/Edit buffer, added shortcut Ctrl+J for "Go to address" command (duplicate of F9 shortcut)
PG4UW: View/Edit buffer, local "Load data" procedure now allows to load also Intel HEX file format
Adapter DIL48/QFN48-1.02 ZIF APM32-1, support enhanced
Adapter DIL48/QFP100 ZIF STM32-DSI-1, added real support (was virtual only)
Adapter DIL48/QFP100-1.02 ZIF APM32-1, support enhanced
Added adapter: Bottom R-TSOP48 NOR-2
Added adapter: DIL48/BGA140-2 ZIF LT-1
Added adapter: DIL48/microSD-1 ZIF eSD-1
Added adapter: DIL48/QFN20-5.02 ZIF GD32-1
Added adapter: DIL48/QFN32-2.02 ZIF GD32-2
Added adapter: DIL48/QFN40-2.02 ZIF TPS53-6
Added adapter: DIL48/QFN48 ZIF STM32-2&GD32
Added adapter: DIL48/QFN48-1.02 ZIF STM32H5-1
Added adapter: DIL48/QFN56-1.02 ZIF MP-21
Added adapter: DIL48/QFP160-2.03 ZIF-CS PLD-7
Added adapter: DIL48/QFP48-1.02 ZIF APM32-2
Added adapter: DIL48/QFP64-1.02 ZIF APM32-2
Added adapter: DIL48/VQFN29 ZIF XDP71-1
Added adapter: DIL48/SD card(1)
Added adapter: DIL8/QFN8-13.02 ZIF FM25V-1
Added adapter: DIL8W/SOIC8 ZIF 150mil CY nvSRAM-1
Dallas/Maxim DS2506 series, Algorithm optimized
Espressif ESP32-C3, ID check procedure improved
Espressif ESP32-C3 series, programming of eFUSE area improved
Espressif ESP32-C3 series, support of eFUSE BLOCK0 added
ITE Tech. Inc. IT5121VG-I-xxx, enter to the Flash Mode modification
Macronix MX25U25645GXDx54 [BGA24] (Quad I/O), improved Protected memory options display
Microchip dsPIC33EP256MU810, Device info updated
Microchip PIC16C73B, PICMicro checksum calculation added
Microchip PIC24FV16KM204, power-on procedure improved
Microchip (SST) SST39SF010A-xx-xx-WH [TSOP32], changed device name and backward project compatibility
MPS MP2869A [TQFN56] (Multiple Configuration), Verify operations improved
National Semicond./TI (TMS) COP8Sxx7, programming procedure modified
SST SST39SF010A-xx-xx-WH [TSOP32], changed device name and backward project compatibility
STMicroelectronics STM32H5xx devices, programming algorithm modified
STMicroelectronics STM32H7 devices, loading of the option bytes area for IntelHex and Motorola file formats modified
STMicroelectronics STM32L4xx, unused bits for WRPxA and WRPxB option bytes treatment changed
TI (TMS) MSP430FR2476, power-up procedure modified
Micron MT25QU128ABA1E [DFN8 6x5] (Quad I/O)(FL-01), supported programmers restriction removed
Altera EPM7128S [TQFP100](SVF), EPM7128S [TQFP100](Jam), pgm parameters assignment bug fixed
Atmel Atmegaxx08/xx09 series and AVRxxDA/DB series, power on sequence bug fixed
Microchip PIC18FxxKxx devices, default value for Configuration bits fixed
Micronas HAL3930, Window 'View/Edit contents of registers' corrected.
Silicon Laborat. EFM32PG23B210F512 (ISP), Device operation options menu bug fixed
STMicroelectronics STM32H5 devices, WRPSGN1R register setting bug fixed
Winbond W25Q32JWxxxQ [SOIC8-150] (QuadSPI), Unexpected error 1 bug fixed
