New software - Version 4.10
Postby Dataman (Daniel Smith) » 20 Mar 2026 14:34
Version 4.10 features the following amendments:
Improved work with project serialization associated files, more access attempts if a file has access denied, increased security against file loss by creating a backup file in the background
Added adapter: BGA-Bottom-569
Added adapter: BGA-Top-134a ZIF
Added adapter: BGA-Top-263a ZIF-CS
Added adapter: DIL48/BGA144-6 ZIF LTM-2
Analog Devices/Linear Technology LTCxxxxx, LTMxxxxx, Main checksum and DPCRC32 improved
Analog Devices MAX20816B, programming procedure improved
ARTERY AT32xxx, Verification after programming set as mandatory, with no option to turn it off
Atmel/Microchip AT32UC3L0128/256 in TQFP48, QFN48 and TLLGA48 packages, Operation stability improved
Atmel/Microchip ATUC L3U series in TQFP64 and QFN64 packages, Operation stability improved
Atmel/Microchip ATUC L4U series in TQFP48, QFN48 and TLLGA48 packages, Operation stability improved
Cypress/Spansion/Infineon S6E2H1xxx devices, added Blank check procedure after chip erase
ESMT EN25QH64A(2A) [DFN8 4x4] (QuadSPI), programming procedure improved
FORESEE F35xQx00xG serial NAND, part name expanded (package code added)
GigaDevice GD32xxx, Verification after programming set as mandatory, with no option to turn it off
Geehy APM32xxx, Verification after programming set as mandatory, with no option to turn it off
Hitachi/Renesas HD637xxxx series, H647xxxx series, Verification options modified
Macronix MX25L25673Gxxx-10, changed device name and backward project compatibility
Microchip PIC16HV753, power-on procedure improved
Microchip SST25WF020A, SST25WF040B, verify operation improved
MindMotion MM32xxx, Verification after programming set as mandatory, with no option to turn it off
Mitsubishi/Renesas M30000 series, M37000 series, M38000 series, Verification options modified
MPS MP2960, programming algorithm improved
NAND flash devices, Verification after programming set as mandatory, with no option to turn it off
NEC/Renesas uPD70F373x, programming speed increased
NEC/Renesas uPD75P008GB [QFP44], uPD78P4038GC [QFP80], Verification options modified
Nordic nRF54H20-CKAA, programming procedure modified
NXP MCXA143 [VQFN32], programming algorithm improved
OneNAND devices, Verification after programming set as mandatory, with no option to turn it off
PUYA PY32xxx, Verification after programming set as mandatory, with no option to turn it off
Qorvo PAC5256QX (ISP-SWD), initialization sequence improved
Silicon Laborat. BGM11x, BGM12x, MGM111x, correct loading of User data page and Lock bit page for motorolaHEX file
Silicon Laborat. EFR32BG1x, EFR32FG1x, EFR32MG1x, correct loading of User data page and Lock bit page for motorolaHEX file
Silicon Laborat. Si4010, programming procedure modified
Sony CXP846P32 [TQFP80], CXP846P40 [TQFP80], CXP846P48 [TQFP80], Verification options modified
STMicroelectronics STM32F1xx, Option bytes reload modified (POR used instead of system reset)
STMicroelectronics STM32xxx, STR7xx, STR9xx, Verification after programming set as mandatory, with no option to turn it off
Toshiba TMP47P series, TMP86P series, TMP87P series, TMP88P series, Verification options modified
Toshiba TMP89P series, TMP90P series, TMP91P series, TMP93P series, Verification options modified
FORESEE F35SQB002G [WSON8], internal ECC controller support fixed (ECC Mode Bit (ECC-M) support added)
Renesas R5F56604xxxx programming addresses offset bug fixed
STMicroelectronics STM32L4+, RDP level 2 activation evaluation fixed
STMicroelectronics STM32L4xx, RDP level 2 activation evaluation fixed
STMicroelectronics STM32WLEx, RDP level 2 activation evaluation fixed
TI (TMS) TPS6699x, programming bug fixed
