New software - Version 3.20
Posted: 11 Dec 2015 16:24
Version 3.20 features the following amendments:
Improved dialogs Load file/project to prevent main file list disappearing when accessing network location in Windows XP
Modified selftests (for all programmers), if SW doesn't detect properly inserted Diagnostic pod the selftest will not be interrupted
Bug fixed in selftest (ERROR: #080FH)
Fixed default setting of Programmer activity log file name in multiprogramming mode starting by customer (not by PG4UWMC). Index of site is appended to log file name.
Fixed detection of multiply instances of PG4UW starting on one computer. When the maximum allowed count of PG4UW instances is reached, no other instances are allowed to run.
Checksum correctly written to Programmer activity log after loading of project for large devices (over 64MB)
Atmel ATmega163, removed erase parameters in "Device operation options"
Atmel ATSAM3S1AB, programming options procedure improved
Atmel ATSAMG55G19A, added CRC in programming algorithm
Elmos E909.06, algorithm improved to CRC check
Macronix MX25L12835F, erase speed increased
Microchip dsPIC30F5011, improving the stability of pgm. actions
Microchip PIC16F182x, added DEBUG configuration bit in Alt+S menu
Nordic nRF51xx, added hex address range check
Renesas R5F52105xxFM [LQFP64] Boot mode, R5F52106xxFM [LQFP64] Boot mode, R5F52107xxFM [LQFP64] Boot mode, R5F52108xxFM [LQFP64] Boot mode, added automatic remapping of input files
Sharp LH28F256BFHT-PTSLZ6 [TSOP56], power-up sequence modified
SyncMOS SM39R08A3Uxxxx, SM39R16A3Uxxxx, programming algorithm improved
TI (TMS) UCD9090 [QFN48] (P+D), verification procedure improved
Atmel AT91SAM7SE512 [LFBGA144], Insertion test bug fixed
Atmel ATSAM3A/X, Lock bits verification procedure bug fixed
Atmel ATSAMD20G18A, bad size of internal flash memory fixed
Hynix H27U1G8F2C [TSOP48] (LGE-56), ECC library fixed
Intel D27011, programming procedure bug fixed
Lattice L-ASC10, programming of Usercode bug fixed
Macronix MX29LV400CB [TSOP48], AutomaticYes bug fixed
Microchip (SST) SST89E516RD2, erase procedure bug fixed
NEC/Renesas uPD70F357x, package information fixed
NEC/Renesas uPD70F361x, programming of security bit bug fixed
NXP LPC822M101 [HVQFN33], LPC824M201 [HVQFN33], Manufacturer / device ID check error fixed
Renesas R5F10Axx, R5F10Bxx, R5F10Pxx [WQFN48], insertion test bug fixed
Rohm BR93L46FV-W [TSSOP8], insertion test bug fixed
Serial NAND flash devices, ONFI Parameter Page decoder fixed
TI (TMS) UCD9090 [QFN48] (P+D), UCD9090 [QFN48] (D), typo error in General info fixed
Toshiba TC58NVG0S3HTA00 [TSOP48] (LGE-55), ECC library fixed
