New software - Version 3.22
Posted: 09 Mar 2016 16:12
Version 3.22 features the following amendments:
Licence file "keyfile.val" is no longer required for multiprogramming remote control of ISP devices
Added module AP1 QFP100 ZIF ARM-1
Added module AP1 QFP144 ZIF LPC
Added module AP1 BGA-1372/0746
Adesto Techn. AT45DB641E, correct display of Device pointer in Info window after finishing the operation
Atmel AT90S1200, blank check procedure modified
Atmel Atmega328PB, Device description corrected
Atmel ATmega48/88/168/328, Device info updated
Atmel ATmega48/88/168/328/A/PA (ISP-SPI), power-on sequence improved
Atmel ATSAMDxxxx, special device options menu improved
eMMC devices: add option 'Check only selected byte/s of the Extended CSD register during verify operation'
Microchip PIC18F8585, PIC18F8680, programming procedure improved
Renesas R7F7010713, communication speed modified
Rohm BR93Hxx-W, programming procedure improved
Samsung Hart-m310, Hart-i910 power-up procedure modified
Samsung S3FM02G, programming speed increased
Spansion S29GL128PxxTxxV2 [TSOP56]x16, AutomaticYes modified
TI (TMS) UCD3138, add of unlock password protect
Analog Devices ADUCM320, verifying bug fixed
Atmel AT24C04D, verification bug fixed
Atmel ATSAME70Q21A, programming bug fixed
Intersil ZL2004-01, programming bug fixed
Microchip PIC18F268x/468x, programming configuration bits bug fixed
Microchip SST26VF064B (ISP), programming bux fixed
Microchip (SST)/SST SST89xxxx devices, erase before programming bug fixed
NXP LPC1226/301 [LQFP48], programming bug fixed
Renesas R5F10xxx [WQFN40], insertion test bug fixed
Sandisk SDIN8DE2-4G [FBGA153], product name bug fixed
Spansion S25FL256SxxMxx00 [SO16] (QuadSPI), power-down sequence bug fixed
STMicroelectronics STM32L1xx, dual-bank EEPROM programming bug fixed
Winbond W25Q256FV, programming status register error fixed
