New software - Version 3.22
Posted: 09 Mar 2016 16:14
Version 3.22 features the following amendments:
Licence file "keyfile.val" is no longer required for multiprogramming remote control of ISP devices
Adesto Techn. AT45DB641E, correct display of Device pointer in Info window after finishing the operation
Atmel AT90S1200, blank check procedure modified
Atmel Atmega328PB, Device description corrected
Atmel ATmega48/88/168/328, Device info updated
Atmel ATmega48/88/168/328/A/PA (ISP-SPI), power-on sequence improved
Atmel ATSAMDxxxx, special device options menu improved
eMMC devices: add option 'Check only selected byte/s of the Extended CSD register during verify operation'
Microchip PIC18F8585, PIC18F8680, programming procedure improved
Renesas R7F7010713, communication speed modified
Rohm BR93Hxx-W, programming procedure improved
Samsung Hart-m310, Hart-i910 power-up procedure modified
Samsung S3FM02G, programming speed increased
Spansion S29GL128PxxTxxV2 [TSOP56]x16, AutomaticYes modified
TI (TMS) UCD3138, add of unlock password protect
Analog Devices ADUCM320, verifying bug fixed
Atmel AT24C04D, verification bug fixed
Atmel ATSAME70Q21A, programming bug fixed
Intersil ZL2004-01, programming bug fixed
Microchip PIC18F268x/468x, programming configuration bits bug fixed
Microchip SST26VF064B (ISP), programming bux fixed
Microchip (SST)/SST SST89xxxx devices, erase before programming bug fixed
NXP LPC1226/301 [LQFP48], programming bug fixed
Renesas R5F10xxx [WQFN40], insertion test bug fixed
Sandisk SDIN8DE2-4G [FBGA153], product name bug fixed
Spansion S25FL256SxxMxx00 [SO16] (QuadSPI), power-down sequence bug fixed
STMicroelectronics STM32L1xx, dual-bank EEPROM programming bug fixed
Winbond W25Q256FV, programming status register error fixed
