New software - Version 3.23
Posted: 08 Apr 2016 14:25
Improved the Selftest with diagnostic module
Added support of AP1 BGA-0998/0999 module
Added support of AP1 QFN32 ZIF NUC-1 module
Added support of AP1 QFN44 ZIF XMEGA-1 module
Added support of AP1 QFN8-1 ZIF SFlash-1 module
Added support of AP1 QFP100 ZIF CY-2 module
Added support of AP1 QFP100 ZIF PLD-12 module
Added support of AP1 QFP100 ZIF PLD-3 module
Added support of AP1 QFP48 ZIF PLD-1 module
Added support of AP1 TQFP100 ZIF PLD-2 module
Added support of AP1 TQFP100-2 ZIF PLD-1 module
Added support of AP1 TSOP40 ZIF 18.4mm NOR-2 module
Added support of AP3 QFP100-1.02 LPC-1 module
Added support of AP3 QFP100-1.02 LPC-8 module
Added support of AP3 QFP208-1.02 LPC-1 module
