New software - Version 2.69
Posted: 15 Nov 2011 15:11
Version 2.69 features the following amendments:
Altera EPM3512A, fuses addressing bug fixed
Atmel ATSAM3Uxx, device operation options <Alt+S> menu bug fixed
IDT ICS280 (new rev.) [TSSOP16], programming bug fixed
Freescale Semic., Motorola MC68HC68SEC811E2 [PLCC52], algorithm bug fixed, adjusted to use also via USB
Freescale Semic., Motorola MC68HC711D3, algorithm bug fixed
Hynix HYC0SEH0AF3 [FBGA137], HYC0SEH0MF3 [FBGA137], HYI0UIJ0MF3 [FBGA137], package info fixed
Microchip PIC18F85J90 (ISP), ID check procedure bug fixed
Numonyx JS28F00AM29EWH [TSOP56], converter test error fixed
Numonyx, STMicroelectronics NAND512W3A2CZA [VFBGA63], NAND512W3A2DZA [VFBGA63], ID check bug fixed
Nuvoton/Winbond ISD15102, overcurrent error fixed
Nuvoton/Winbond W78E052D, configuration bits bug fixed
Samsung K9F1G08U0C [TSOP48] (LGE-20), "blank" partition #0 after programming bug fixed
Spansion S29GL256PxxFxxS7 [FBGA64], programming bug fixed
STMicroelectronics M58LW128H [VFBGA56], wrong info about suitable converter fixed
STMicroelectronics STM8T141, power-up procedure bug fixed
STMicroelectronics STR7xx family, fixed boot-up sequence
Winbond W25Q80BV (QuadSPI), programming bug fixed
Xilinx XCR3256XL [FTBGA256], overcurrent protection system bug fixed
Xilinx XCFxxP, bug fixed during loading of MCS/HEX/BIN files in case of missing CFI file
Atmel AVR-converters: test of converters bug fixed
Fixed bug in displaying general info invoked by menu command Help / Supported devices
Fixed bug in checking socket converters, causing converter test error in specific situations
Actel QFN108/132/180, VQFP128/176, socket pictures added
Atmel AT28C64B, AT28BV64B, AT28HC64B, AT28C256, buffer size change
Atmel AT45DBxxxD, programming algorithm improvement
Atmel ATtiny48/88, correction of the BODLEVEL values
Cypress CY8C24994 [QFN68], converter test modified
Freescale Semic. 9S12XEP100, memory map description in Device Info window improved
Freescale Semic. MC9S12XDT256, stability of programming algorithm improved
Microchip dsPIC33FJ Family, programming procedure improved
Microchip dsPIC33FJ Family, power-on procedure with capacitor on VDD pin more than 10uF improved
Microchip PIC16F1xxx, programming configuration words improved
Microchip PIC16F1xxx, added options "Preserve Data memory"
Micron MT29C4G24MAPLAJA [TFBGA137], read/verify operations improved
NEC uPD78F1166 (ISP-UART), description of ISP pins improved
Nordic Semiconductor nRF24LU1P-O17, improving of programming action
Numonyx NAND04GW3B2DN [TSOP48] (LGE-15), modification upon customer's request
Numonyx NAND08GW3B2CN [TSOP48] (LGE-17), modification upon customer's request
Numonyx, STMicroelectronics NAND01GW3B2CZA [VFBGA63] (Thomson-01), algorithm modification upon customer's request
NXP/Philips UOCIII, UOC-TOP, UOC-Fighter, added Part number description into Device info <CTRL+F1>
Samsung K9F8G08U0M [TSOP48] (LGE-18), modification upon customer's request
Samsung K9F8G08U0M [TSOP48] (LGE-18), reading/verification improvement
Samsung KBY00N00HM [FBGA137], read/verify operations improved
Samsung S3F84H5, protection modes programming change
Spansion S29GL256PxxFxxS7 [FBGA64], programming procedure modification
Spansion S71WS128NC0BFxA [FBGA84], programming procedure modification
STMicroelectronics NAND04GW3B2DN [TSOP48] (LGE-15), modification upon customer's request
STMicroelectronics NAND08GW3B2CN [TSOP48] (LGE-17), modification upon customer's request
STMicroelectronics ST7FLITE3xF2x, programming/reading speed increased
STMicroelectronics ST7FLITE3xF2x, power up procedure improvement
STMicroelectronics STM8S103K3U, STM8S903K3U, power-up procedure improved
Toshiba T5CN5 [LQFP100], programming algorithm improved
Toshiba TC58NVG2S3ETA00 [TSOP48] (LGE-16), modification upon customer's request
Winbond/Nuvoton ISD15102, power-up procedure improvement
Xilinx XC9500 [PQFP160], improving of overcurrent protection system
NAND01GW3B2CZA [VFBGA63] (Thomson-01), algorithm modification upon user request
