New software - Version 3.26
Posted: 29 Sep 2016 16:10
Adapter Bottom TSOP48 NOR-3 + Top TSOP48 ZIF 18.4mm, identification modified
Adapter DIL20W/SOIC20 ZIF 300mil (id), identification procedure modified
Adapter DIL16W/SOIC16 ZIF 300mil SFlash-1a, Automatic Yes! bug fixed
