Added support of AP1 BGA-0452/0453 (Enpl) module
Added support of AP1 LQFP48-1 ZIF MB9-1 module
Added support of AP1 QFP100 ZIF PLD-22 module
Added support of AP1 QFP144 ZIF PLD-16 module
Added support of AP1 QFP64-2 ZIF NEC-1 module
Added support of AP1 QFP80 ZIF LPC-1 module
Added support of AP1 TQFP100-2 ZIF PIC-1A, AP1 TQFP44 ZIF PIC-1 modules
Microchip PIC12F519 [DFN8], added support
NXP P87C51FB [PQFP44], programming bug fixed
New software - Version 3.26
