New software - Version 2.63
Posted: 18 Nov 2011 12:20
Version 2.63 features the following amendments:
Atmel AT25128 [SOIC16], insertion test bug fixed
Atmel AT89C51RE2 [VQFP44], package details bug fixed
Cypress CY7xxxV, ID check routine bug fixed
Freescale MC9S12XET256, instability bug fixed
Hynix HY27US08121B [TSOP48] (ALT-01), a problem with huge number of invalid blocks in device solved
Lattice ispLSI1032/E/EA, ispLSI2064/A [PLCC84, TQFP100], power up bug fixed
Luminary Micro LM3S101 [SOIC28], LM3S617 [LQFP48], CPU core halt sequence problem solved
Microchip dsPIC33FJ32MC202, configuration words bug fixed
Microchip PIC16F616, configuration word programming bug fixed
Microchip PIC18F/LF1xK50, identification procedure bug fixed
Micron MT29F2G08ABCWP [TSOP48], ID check bug fixed
Numonyx M25PX64-V [SO16], fixed fatal error
Ramtron FM30C256, programming bugs fixed
STMicroelectronics M24C64-R [MLP8], programming bugs fixed
STMicroelectronics M28W320HSTxxZA, package drawing bug fixed
Winbond W25Q32BV [SOIC16], Device insertion test error fixed
Xicor X25040, programming bugs fixed
Xicor X84xxx, programming bugs fixed
Zilog Z86E33/733/E34, Z86E43/743/E44, verify algorithm bug fixed and improved option bits setting
Block locking mechanism for relevant Samsung MCP nand flash devices fixed - if locked blocks should be programmed again, they are skipped as being invalid.
Fixed bug in displaying insertions test's error message
Altera EPM7xxxE, improving of read/verify actions
Atmel AT28C64B, ID area programming added
Atmel ATxmega256A3, power up sequence modified
Atmel ATxmega series in ZIF and ISP, bootloader section added
Atmel AVR32 series, read, verify and blank_check functions modified
Atmel AVR32 series, programming of GPFuse bits improved
Cypress CY7xxxV, adding of user code displaying, improving of programming stability
Eon Silicon Dev. EN25F40, EN25F80, EN25T80, EN25D80, update the Protected Area Sizes definition according to the newest datasheet
Hynix HY27UF084G2B [TSOP48], invalid blocks identification fixed
Lattice ispClock5000, improving of the programming algorithm according to the latest pgm. spec.
Lattice ispLSI1032/E, ispLSI1016, improving of actions stability
Lattice LC4xxxB/C/V [TQFP176], increasing of overrcurrent protection limits
Microchip PIC16C74A, PICMicro checksum calculation added
Microchip PIC24HJ256GP206 (ISP), power-up procedure improved
NEC uPD70F3017A, uPD70F3033AY, uPD70F3210, uPD70F3214, programming speed increased
NEC uPD70F3453 (ISP-SPI), programming speed increased
Ramtron FM31xxx [SOIC14] and FM32xxx [SOIC14], correction of recommended converter
Renesas Technology R5F21257SDFP (ISP-single wire), power-up modified
Renesas Technology R5F21257SDFP (ISP-single wire), Targer supply voltage option enabled
Renesas Technology R5Fxxxx, Boot area verification canceled
Samsung K5G5629AT [FBGA133] insertion test modification
Samsung K9G4G08U0B [TSOP48], read/verify operation stability improved
Sharp LH28F640BFHG-PBTLE7 [CSP48], programming modification
Spansion S29GL256P, verify and programming procedure modification
STMicroelectronics STM8AF6166T [LQFP32] power up sequence modification
Toshiba TMP86FS49AFG, blank, read and verify procedure modified
DIL48/QFP52 ZIF R8C/Tiny-1 converter authentication modified
Added NC pins list of socket converter DIL48/TSOP56 ZIF 18.4mm Flash-4 (x16) for "Automatic YES!" feature
Device operation options for STM8 series in ISP mode improved
Option bytes data modification after loading data for STM8 devices
Cypress clocks devices, Commercial/Industrial grade test added
Added problem identification during partition table loading
