New software - Version 2.76
Posted: 18 Nov 2011 12:29
Version 2.76 features the following amendments:
Added possibility to enable or disable SW readiness indication to detect new device in ZIF socket by a sound signal (in Automatic YES! mode)
Improved setting of indication of active Automatic YES! mode, also added possibility to modify this setting from Pg4uwMC
Added support of new CHIL file format for CHiL Semiconductor devices
Changed term "Log window" to new term "Programmer activity log"
Fixed RAM operation memory size test to 220MB. If amount of RAM is lower, software will display warning with proper information.
"Privileged instruction exception", programmer find bug fixed
Project checksum type detection for SW version older than 2.72 bug fixed
Fixed Save file/project dialog behaviour in Windows 7, to correctly accept file name specified by user in "File name" edit box
Fixed in Pg4uw for Windows Vista / Windows 7 - prevent software from using VirtualStore UAC file virtualization (substitution of drive c:\ for [VirtualStore] folder, etc...)
Fixed in Pg4uwMC - button Settings is correctly enabled after deactivation of Protected mode
Fixed in Pg4uwMC - sound settings for good and failed operations are now correctly accepted even immediately after connecting of Programmer Sites
Fixed in Pg4uwMC - in case of load project error is forbidden device operation by disabling of button "Run All" even if Auto YES! mode is selected
Fixed in Pg4uwMC - checksum test for older projects improvement to prevent warning messages "Project checksum does not match between Sites"
Altera, TI (TMS) EP18xx, added support of Emulation Technology AS-68-40-03PG-6 adapter
Atmel AT45DB021D, AT45DB081D, option 'Page Program with Built-in Erase' added
Atmel AT91SAM7SxxC, improving of entering pgm. mode
Cypress CY8C3866LTI-030 [QFN68], programing procedure improved and added support for ES3 revision
Dallas/Maxim DS1250, power-up and power-down sequence improved
Freescale Semic. MCF51EM256, power-up sequence improved
Hitachi HD64F2110BVFA, power-up sequence improved
Lattice ispPAC-POWR1014, improving of programming stability
Lattice LA4xxx, LC4xxxx, LC5xxx, LXxxx, modification of reading/verifying/programming of User Electronic Signature (UES)
Microchip PIC24F16KA101 in ZIF, power-on procedure on high voltage modification
Microchip PIC24FJ64GA004, programming configuration bits procedure improved
Mitsubishi M5M29GB320VP [TSOP48], programming procedure improved
NEC uPD78F0034AY, verification procedure improved
NEC uPD78F0338 (ISP-SPI), synchronization procedure improved for channel 1, CSI1
Numonyx JS28F256M29EWL [TSOP56], unprotect procedure improved
Renesas Technology M38227PCFP, programming procedure improved
Renesas Technology R5F212D8S (ISP-single wire), R5F21255SYFP (ISP-single wire), R5F21258SNFP (ISP-single wire), speed increased
Sharp LH28F640SPHT [TSOP56], some improvements added
Spansion S29GL-N series, sector erase operation improved
TI (TMS) TIBPAL22VP10, device blank check test improved
Winbond W25Q40BV, changed device names from W25Q40BV to W25Q40BV (dc<1023) and backward project compatibility correction
NAND flash devices - custom algorithm FJT-01 modification upon user request
NAND flash devices, check invalid blocks feature added
Improved programming adapter checking function
Remove action Blank check before programming for serial EEPROM
Atmel ATmega168, "Unexpected error 1" bug fixed
Atmel ATmega3290P/V [QFP100], package and converter info bug fixed
Atmel ATmega644PV (ISP) (OSCCAL), verification bug fixed
Atmel AVR8 A/PA series, supply voltage range bug fixed
Hitachi HD6473032F, programming bug fixed
M-Square MS8951 (ISP), description of ISP connector pins bug fixed
Maxim ZLF645x0H2864, overcurrent error fixed
Microchip dsPIC33FJ128MC202, dsPIC33FJ128MC204, set of configuration bits bug fixed
Microchip PIC12HV609 [MSOP8], PIC12HV615 [MSOP8], wrong converter assign bug fixed
Microchip PIC16F7x, power-off procedure bug fixed
Mitsubishi M5M29GB320VP [TSOP48], erase bug fixed
National Semicond. NMC27C64, verify and blank check procedure bug fixed
NEC uPD78F1164, uPD78F1164A, uPD78F1166, uPD78F1166A, synchronization procedure bug fixed
NXP/Philips LPC2xxx (ISP), reading procedure bug fixed
Ramtron FM24V02, device ID check error fixed
Rohm BR9010F/20F/40F programming error fixed
Sharp LH28F640SPHT [TSOP56], programming error fixed
STMicroelectronics ST72F344S4T [LQFP44], programming option bytes bug fixed
STMicroelectronics STR735FZ2 [TQFP144], debug/readout protection enable bug fixed
TI (TMS) TIBPAL22VP10, "fatal error" bug fixed
