New software - Version 2.46
Posted: 18 Nov 2011 12:46
Version 2.46 features the following amendments:
93C66 (ISP) x8 devices, address range bug fixed
Cypress CY8C24423A [MLF32], device selection bug fixed
Holtek HT24LC32, verify and read procedure bug fixed
Intel PH28F320C3B/T/GE28F320C3B/T [VFBGA48], GE28F640C3B/T [VFBGA48] - insertion test bug fixed
Lattice LCMXO/XP/ispPACPOWR/ispPACPOWR II/ispPACCLK, USERCODE displaying/storing bug fixed
Microchip dsPIC33FJ16GP304 [QFN44], dsPIC33FJ16MC304 [QFN44], bug fixed
Motorola/Freescale MC68HC711D3, algorithm for USB connection to PC, bug fixed
Motorola/Freescale MC68HC705C9x, algorithm bug fixed, USB support added
NEC uPD75P036 [QFP64], "Converter test - error! [EC:1]" bug fixed
Philips/NXP, TDA12136PS [SDIP64], TDA12156PS [SDIP64], programming bug fixed, improving of entering pgm. mode
Samsung K9F1208x0x [FBGA63], insertion test bug fixed
SGS-Thomson (STM) NAND256R3A2BZA [VFBGA55], ID check bug fixed
SiLab C8051F326/327 ID bug fixed
SST SST34HF32A4, ID check procedure bug fixed
Xilinx XCR3xxxXL, addressing bug fixed
ISP mode for SPI bus serial EEPROM, power supply test bug fixed
IC test, 4094 chip, test vectors bug fixed
Altera EPM7096, improving of ID check test, improving of programming stability
Altera EPM7032/S, EPM7064/S, emulation support device info improving, modification of ID check routine, automatic change to an emulation support of EPM7xxxS as 7xxx
Altera EPM570/G [FBGA256], increasing of overcurrent protection limits
Altera MAX II, improving of programming parameters assignment
Anachip/ICT PEEL18CV8Z, programming bug fixed, improving of signature code reading
ICE ICE27(L)C512, read operation improved
Intel PF38F1030C0ZT, programming speed increased
Microchip PIC12F508, PIC16C621A, PICmicro checksum calculation added
Micron MT29F8G08DAAWC, insertion test improved
Motorola/Freescale MC68HC908AZ60A (ISP), programming speed increased
Renesas M38027E8FP, program and read procedure improved
Samsung K8P6415UQB and K8P3215UQB, programming procedure improved
Samsung K9F1208U0C [TSOP48] code improvements for new datecode of die
SGS-Thompson M28W320CB, programming bug fixed
SGS-Thomson ST7FLITES5Y0B, added function for calculation and setting of calibrating RCCR constants
SGS-Thomson ST72F561AR9T [TQFP64], option bytes programming bug fixed
SGS-Thomson ST72F561AR9T [TQFP64], erasing bug fixed
SGS-Thomson ST7FMC2R7T [TQFP64], programming option bits (PKG[2:0]) bug fixed
SGS-Thomson ST7FMC2R7T [TQFP64], programming option bits (PKG[2:0]) allowed to edit
SGS-Thomson ST72F321AR9T [TQFP64], erasing bug fixed
SGS-Thomson ST7FMC1K4T6, programming option bits bug fixed
SGS Thomson STM32F101CxT6, code improved
SST SST39LF010 [WFBGA34], SST39LF020 [WFBGA34], PowerUp and PowerDown procedures improved
SGS Thomson STR9 and STM32 series, ISP-JTAG support added
TI, MSP430Fxxx series using DIL48/QFP64 ZIF MSP430-1 and JTAG mode, programming speed increased
TI, MSP430Fxxx series in BSL mode, Erase improved
Xilinx XCFxxP, improving of pgm parameters dialog (Alt+S) and adding of CFI file handling
Zilog Z8FMC16100, programming improved
DS28E01-100, programming procedure improved
software for adapter DIL48/QFP144 ZIF XC-1 improved
NAND Flash, bad blocks handling improved
NAND Flash, OneNAND, STR7xx, STR9xx and STM32Fxxx improvements
NAND Flash, modification of bad block table creation for "User Data" mode
NAND Flash, communication timeout at case of huge number of bad blocks and slow computer bug fixed
