isp programming of at89s8252 and at89c5131a
Postby Guest » 10 Nov 2011 12:31
when connecting devices with at89s8252 or at89c5131a with dataman40pro true ISP everything seams to be ok,but only operation wich i can do completely is reading from device the rest of operations(erasing,programing) i can do only 6% after that it gives me error mesage blank checking failed.Is there any special steps in configuration that i need to do related to programing thouse devices over ISP?
Help,thank you in advance,regards.
joedragon
Re: isp programming of at89s8252 and at89c5131a
Postby Dataman (Neil Parker) » 10 Nov 2011 12:31
Hello joedragon,
Are you using the latest version of our software? Currently v2.78
Can you confirm that you have followed our recommendations for connecting to the target devices 100% (Ctrl + F1) ISP Connections details tab?
What is the result of the selftest and selftest plus routines found under the Programmer menu? Can you recreate the errors you mention and then use the "Help | Create Problem report" feature and email the resulting log file to [email protected] for analysis.
Hopefully we can find a solution.
