New software - Version 2.81
Posted: 18 Nov 2011 16:11
Version 2.81 features the following amendments:
JobReports file type changed to 'Rich Text Format *.rtf'
Automatic YES! setting on pg4uwMC bug fixed
Error report from slave site disabled
Working with "Create problem report" in Pg4uwMC bug fixed
Fixed error "Access violation" that might occur sometimes when closing Pg4uw.exe from remote control application (for example from Pg4uwMC).
The error caused Pg4uw.exe not closed correctly and stayed hung in memory.
Fixed error "Access violation" occured in dialog "Automatic YES! wizard"
Fixed error "Integer overflow" that might occure during starting of Pg4uw, when more devices with complicated settings were saved to configuration .ini file
Fixed error handling for load file error, when the file is locked by another application
Improved remote control processing inside Pg4uw to reach lower system load
Fixed bug that caused sometimes to show images of manufacturer logos in dialog "Select device" in black and white
Fixed blinking of main program window in Windows XP, when device operation is completed
Forced permanent display of buffer address range for checksum calculation on main form, changed non-standard control button "Checksum options" to standard button due to better self-explanation of control meaning
ABOV Semiconductor MC80F0604,MC80F0504, programming algorithm improvement
Actel ProASIC3 A3P060/125/250/400/1000 based devices, added STAPL file version dependency information to Device Info window
Asix AX11005 [LQFP80], power-up sequence improved
Atmel AT25DF021, AT25DF041A, AT25DF081A, AT25DF161, AT26DF161-S, AT25DF321A, AT25DF641, speed up of reading
Atmel AVR series, ISP schematics changed
Atmel AVR32 series, added ability to cancel erase and delay after unsuccessful erase shortened
Cypress CY8C3xxxxxx, update device revision checking
Dallas/Maxim DS89C4xx, verifying Options added
DIL48/QFP160 ZIF-CS PLD-3 (70-2349), programming parameters improvement
Freescale Semic. MC68HC705C9A, Vpp voltage for read/verify/blank corrected
Freescale Semic. MC9RS08KAx, reference trimming frequency trimmable through whole range
GMT G7311D, programming procedure improved
Hynix HY27UF084G2B [TSOP48] (HUA-01): algorithm modification upon customer request
CHiL Semiconductor CHL8112A, verifying procedure improved
Ilitek ILI2102s, ILI2103s, programming procedure improved
Microchip dsPIC33FJ256GP710A, verification procedure improved
Microchip PIC18F8680, into Alt+S menu added set of ECCPMX bit
Microchip PIC18FxxJxx, power-on procedure improved
Microchip PICxxFxxx Family, added storing the value of VDD to the project file for the ISP devices
Micron MT29F1G08ABBDAH4 [VFBGA63]: read/verify reliability improved
NEC uPD70F3371, synchronization procedure improved
NEC/Renesas uPD78F0513A, power-up procedure improved
NEC uPD78F055x, synchronization procedure improved
Renesas M38039FFSP [SDIP64], programming speed increased
Renesas R5F213J5CxNP [QFN36], power-down sequence modified
Samsung K9HCG08U1M [TSOP48]: read/verify reliability improved
Samsung KM2817A; programming algo improvement
Silicon Laborat. C8051T6xx, power-up sequence improvement
Sonyx SN8P2711P [PDIP14], calibration improved
Spansion S29AL008JxxTxx02 [TSOP48], Device info corrected
STMicroelectronics ST72F324K4B, programming speed increased
STMicroelectronics STM32Fxxx devices: device detection in Auto YES! mode improved
TI (TMS) MSP430F5xxx, added support of BSL memory
TI (TMS) TMS320F2806 [QFP100], improving of overcurrent protection system
Weltrend/Nuvoton WT78E365/WT78E365A, erase sequence modified
Atmel AT32UC3B1512, ID code bug fixed
Atmel AT32UC3B1512 [QFN48], programming the fuse bits bug fixed
Atmel AT90USB82/162, ATmega2561 ISP pins description fixed
Atmel ATmega644PV (ISP) (OSCCAL), faulty bootloader changed
Atmel ATtiny10 (ISP-TPI), ISP pins description bug fixed
Cypress CY8C27243 (ISP), power-up sequence bug fixed
Freescale Semic. MC9S08QExx [LQFP44], communication error fixed
Freescale Semic. MC9S08SG8 (ISP), entering BDM mode error during verify fixed
Freescale Semic. MC9S12Hxxx (ISP), communication error fixed
Freescale Semic. MC9S12HZ128 [LQFP112], verification error fixed
Fremont FT24C64A, programming error bug fixed
Ilitek ILIM2i, Automatic YES bug fixed
Installer, modification of language settings is applied for PG4UW environment, bug fixed
Lattice LC4064ZC [TQFP48], ID check sequence bug fixed
Microchip dsPIC33FJ128MC510A, dsPIC33FJ256GP506A, dsPIC33FJ256GP510A, dsPIC33FJ256MC510A, dsPIC33FJ256MC710A, verification procedure bug fixed
Microchip PIC18F2xxx, load/save procedure from/to hex file for EEPROM bug fixed
Microchip PIC18F45K22 [UQFN40], Insertion test procedure bug fixed
Microchip PIC18F8680, programming procedure of configuration bits bug fixed
Nand flash devices: fixed bug in non-Quick Program mode (also the cause of problems with relocation table writing in many customized algorithms)
Samsung KM2817A, programming bug fixed
Sharp LH28F320BFHE-PTTL [TSOP48], programming procedure bug fixed
STMicroelectronics STM32F10xx6; Device ID code bug fixed
TI (TMS) MSP430FG437, ID check bug fixed
Toshiba TMPM324F10FG [LQFP144], Automatic YES! bug fixed
Xilinx XCR3128XL, addressing bug fixed
