New software - Version 2.56
Posted: 18 Nov 2011 16:45
Version 2.56 features the following amendments:
Cypress CY22150F, programming procedure bug fixed (test Industrial/Commercial bit)
Aplus Flash AF24BC128, insertion test bug fixed
ST Microelectronics NAND128W3A2BN [TSOP48] (ALT-02), Access Method menu bug fixed
ST Microelectronics STM32F103C6xxA, a memory pages count bug removed
Spansion S29NS032JxxB, ID check and insertion test bug fixed
M36W0R5040T5 [TFBGA88], erase procedure bug fixed
Intel RC28F256K3C, blank check error message bug fixed
Atmel AT89C51ED2 (ISP), blank check procedure bug fixed
SST SST38VF6402, SST38VF6403, SST38VF6404, wrong ID codes fixed
Numonyx NAND02GR3B2DZA [VFBGA63], NAND02GW3B2DZA [VFBGA63], package/adapter fixed regarding to datasheet changes (rev. 2 vs. rev. 4)
ESMT F25L32PA, OTP programming bug fixed
Macronix MX25L3205D, (Alt+S) menu bug fixed
ST Microelectronics STR910FAW32X6, ISP algorithm fixed
Microchip PIC18F4520, power-up procedure bug fixed
Motorola, Freescale Semic. HC08, trimming result evaluation bug fixed
SunplusIT SPCP866E2A, programming bug fixed
Samsung K5E5657ACB [FBGA121], insertion test fixed
Raydium RM24C32, power-on procedure bug fixed
Hynix HY27US08121B (LGE-01) [TSOP48], RBA table validation procedure bug fixed
Xilinx XC95288XL/XV [FTBGA256], device package change to [FBGA256]
Atmel ATtiny43u/23u, clock settings repaired
Atmel ATtiny23u, Flash size corrected
Philips/NXP LPC2xxx series, device size bug fixed
Renesas Technology R5F212BASxFA, read/verify procedure modification
Macronix MX25L6405D, revised voltage for program/erase acceleration
STMicroelectronics M59PW1282, erase procedure modification
Winbond/Nuvoton W78L052C [PLCC44], erase procedure improved
Altera EPM7xxxB, improving of pgm. parameters assignment
EON EN25xxx, device ID check improved
SanDisk mDOC H3, change of device names by added suffix (DSH) and added support of mDOC H3 image format
Philips/NXP P89LPC9xxxx, programming UCFG2 register added
Silicon Laborat. C8051F353, programming algorithm improved
EM Microelectronic EM4176, programming algorithm improved
AMD Am29F010B, command access to the flash modified
Toshiba TC58FVM6T5B, programming modified
Xilinx XC95xx/XL/XV [CSP48], improving of pgm. parameters assignment
Xilinx XC95xx/XL/XV [CSP48](Jam), XC95xx/XL/XV [CSP48](SVF), improving of pgm. parameters assignment
Xilinx XCR3xxXL [CSP48], improving of pgm. parameters assignment
Xilinx XCR3xxXL [CSP48](Jam), XCR3xxXL [CSP48](SVF), improving of pgm. parameters assignment
Lattice ispLSI2032VE/VL [caBGA49], improving of pgm. parameters assignment
Lattice ispLSI2032VE/VL [caBGA49](Jam), ispLSI2032VE/VL [caBGA49](SVF), improving of pgm. parameters assignment
Altera EPM7xxxAE/B [UBGA49], improving of pgm. parameters assignment
Altera EPM7xxxAE/B [UBGA49](Jam), EPM7xxxAE/B [UBGA49](SVF), improving of pgm. parameters assignment
Motorola, Freescale Semic. HC08, added skipping of blank pages during programming
M36W0R5040T5 [TFBGA88], interface for programming adapter improved
Spansion S29GL256P, unprotect modification
Micron MT29F1G16ABCHC [VFBGA63] (EPS-2), customer support modification
Motorola, Freescale Semic. HC08, trimming result evaluation enhancements
Freescale MCF52x in ZIF mode, disabled adjustment of "Clock Configuration Registr"
Eon Silicon Dev. EN25F20, update item "Protected memory", <Alt+S> options
Altera MAX II/Z, device Erase action is mandatory and is executed before Program action
General info modified for ST7 devices (separately) at the base of EEPROM presence
PICmicro checksum for Microchip PICmicro devices is written to Log window
