New software - Version 2.60
Posted: 18 Nov 2011 16:48
Version 2.60 features the following amendments:
AMD/MMI PAL14L4, programming and verification bug fixed
Samsung K8P2815UQB, read and verify procedure bug fixed
Chipcon/TI CC2510-F16 (ISP), programming Lock Protection Bits bug fixed
EON EN29LV640L/H, sector group unprotect bug fixed
Spansion S29WS512P, address bus pins bug fixed
Microchip PIC16F91x, programming User IDs bug fixed
NEC uPD70F3423, programming bug fixed
SST SST39LF040 [TFBGA48], bugs fixed in programming and insertion test
Zilog Z8Fxx80 [QFN44], Z8Fxx80 [LQFP44], power-up procedure bug fixed
Numonyx JS28F512M29EW [TSOP56], insertion test bug fixed
SST SST34HF324G [LFBGA48], Unexpected error 1 [IEC:2, D:04] fixed
Micron MT29F2G08AABWP [TSOP48], ID check bug fixed
Catalyst CAT24C128, programing procedure bug fixed
LH28F640SPHT [TSOP56] x16, bug fixed in blank check procedure
Freescale Semic. MC9S12XET256 (ISP), programming bug fixed - related to specific buffer content
Freescale Semic. MC9S08DN16, select from list of supported devices bug fixed
Intel PF38F4050M0Y3DF [SCSP56], PF38F4050M0Y3DF [SCSP56] (BEFP), PF38F5060M0Y3DE [SCSP56] (BEFP), wrong information about suitable converter fixed
STMicroelectronics M27C512 package info bug fixed
Hynix HY27UF081G2A [TSOP48] and HY27SF081G2A [FBGA63] devices: invalid blocks check bug fixed
NAND flash device supported by customer algorithm (FOX-02): invalid blocks table save bug fixed
Japanese language support added
Nordic Semicond. nRF24LE1, improving of entering pgm. mode
Samsung K8P2815UQB, power-up procedure improved
Samsung K8P2815UQB, programming procedure to Quad Word Program mode upgraded
Samsung K8F5615ET, K8F5615EB, K8F5715ET, K8F5715EB, misunderstanding marking of this devices changed
NXP/Philips LPC2138 (ISP), improving of entering pgm. mode
Philips/Signetics N82HS321, programming modification
Eon Silicon Dev. EN25F16 and EN25T16, disable the OTP security sector
Hitachi HN27C4096x, programming procedure improved
Finisar SFP, programming and verify procedure improved
SST SST34HF324G [LFBGA48], power-up improved and ID check modification
AMD/Lattice/Vantis MACH435 [PLCC84], device support adding, improving of pgm. algorithm
Philips/NXP TDA11116PS/N3 [SDIP64], improving of entering pgm. mode
Philips/NXP, all UOC-TOP, load DMP files procedure improved
Atmel AT32UC3A family, erase and programming functions improved
Cypress CY8C27243, power-up sequence modified
Altera EPM3128A [FBGA256], insertion test improved
Altera EPM3256A/512A [FBGA256], converter pinout improved
Winbond/Nuvoton W77E516, W77E516A, W77LE532, W77L532A, W77LE516, W77L516A, W79E532, W78LE365, W78E365, change of device package from [TQFP] to [QFP] or [PQFP]
Coreriver/Gencore GC87C510, improving of entering pgm. mode
Microchip PIC10Fxxx Family, display of User IDs improved
Microchip PIC16C74B, PICMicro checksum calculation added
Customer device Hynix HY27UT088G2A [TSOP48] (AML-01): programming speed increased
Changed memory maps and related options for Freescale's 9S12X MCUs to meet format generated by CodeWarrior
Custom NAND flash devices with specialized file load: file load error codes explanation added to Device Info
