New software - Version 2.70
Posted: 18 Nov 2011 16:54
Version 2.70 features the following amendments:
Actel A3P060 (ISP-STP), programming parameters assign bug fixed
Actel IGLOO, ProASIC3 and Fusion series ISP-STP, programming parameters assign bug fixed
Amic A25Lxx32 family, programming bug of Configuration and Status registers after load of project fixed
Atmel AVR32 series, initialization bug causing programming problems fixed
Atmel ATtiny44/84[MLF20], ID bug fixed
Atmel ATmega16HVA, reading bug fixed and programming procedure improved
AUO AUO-G1422.2H [TQFN32], insertion test bug fixed
Freescale Semic. MC56F8023 [LQFP32], programming bug fixed
Freescale Semic., MC56F8023 - programming bug fixed
Hynix H27U4G8T2B [TSOP48] (AML-01), "Unexpected error 1 [IEC:98, D:0B]" bug fixed
Infineon SAF-C164CM-4E, SAK-C164CM-4E, programming bug fixed
Microchip dsPIC33FJ128GP202, dsPIC33FJ128GP802, programming configuration words bug fixed
Microchip PIC12F609, PIC12F615, PIC12F617, wrong info about suitable converter in MSOP8 package fixed
Microchip PIC18F4480, configuration bits verification procedure bug fixed
Microchip PIC18FxxKxx, programming configuration bits bug fixed
Microchip PIC18F6585, PIC18F8585, PIC18F6680, PIC18F8680, programming CCP2MX configuration bit bug fixed
Microchip PIC24F16KA102, programming configuration bits bug fixed
Microchip 24xx128 [MSOP8], insertion test bug fixed
Microchip PIC32MX family, load hex procedure bug fixed
NEC uPD78F9177AY, programming procedure bug fixed
Numonyx M58LT256JSTxZA [TBGA64], power up procedure bug fixed
Numonyx M58LT128HSTxZA [TBGA64], erase procedure bug fixed
NXP P89CV51RC2, programming 6x bit bug fixed
Renesas Technology R5F21245SNFP, buffer size bug fixed
Spansion S25FLxxxP family, programming bug of Configuration and Status registers after load of project fixed
Spansion S29WS128RxxBxx00 [FBGA84], programming procedure modification
STMicroelectronics ST62T01C [SOIC16], wrong converter assign bug fixed
STMicroelectronics M27C2001 [TSOP32], device size bug fixed
STMicroelectronics STR71x family: fixed booting of units programmed in previous
SyncMOS SM59R04A2, SM59R03A2, SM59R02A2, programming bug fixed
Winbond W25QxxB/CV family, programming bug of Configuration and Status registers after load of project fixed
Fixed "Access Violation" bug during testing of socket converters DIL48/QFP44 ZIF XMEGA-1
Atmel AT32UC3A [BGA144], added description of BGA package orientation in ZIF socket of converter
Atmel AT91SAM7S, speed up of programming algorithm
Atmel ATtiny13/24/25/44/45/84/85, programming procedure improved
Atmel, more MCS51, speed up of programming algorithm
Freescale Semic., Motorola MC68HC705P6A, algorithm speed-up
Freescale Semic., Motorola MC68HC912xxx, added option to select 4MHz BDM speed for 8MHz XTAL
Freescale Semic., family 9S12XEx - emulated EEPROM functionality supported for ISP programming (full partion DFLASH, EEEPROM programming)
Fujitsu MB96F315 (ISP), missing ISP picture added
Lattice ispPAC-POWR607-01, improving of action stability
Macronix MX25L12855E [TFBGA24], Dual I/O, Quad I/O, changed device names to MX25L12855E [TFBGA24 10x13] and backward project compatibility correction
Microchip PIC18FxxKxx, erase procedure improved
Numonyx PC28F256P30BF [EasyBGA64], programming procedure improved
Numonyx PC28F256P30BF [EasyBGA64], unprotect procedure improved
Philips/NXP TDA12176H/N3 [QFP80], improving of entering pgm. mode
Spansion S29GL128PxxFxxS7 [FBGA64], programming procedure improved
Spansion S29GL256MxxFxxR1 [FBGA64] x16, programming procedure improved
Spansion S29GL256MxxFxxR1 [FBGA64] x16, sector group unprotect procedure improved
Spansion S29GL256PxxFxxS7 [FBGA64], S29GL512PxxFxxS7 [FBGA64], programming procedure improved
SST SST39WF1601xxxxMB [WFBGA48], verification procedure improved
STMicroelectronics ST7FLITEU09x, programming speed increased
STMicroelectronics STM8L101F3P,STM8L101F2U, insertion test modification
STMicroelectronics, STR91x family: added support for binary input files, added support for multiple file load (individual files for each memory location)
STMicroelectronics, STR75x family: core halting procedure improved (debug mode enter)
NAND flash devices: Invalid Block Management option "Do not Used" renamed to "Treat All Blocks"
NAND flash devices: mixed-type multi-partition support released
NAND flash devices: JFFS2 file system preparation support released (Clean Markers)
NAND flash devices: new invalid blocks management methods released - Check IB without Access, Check IB with Skip IB, Skip IB with Excess Abandon
