New software - Version 2.44
Posted: 26 Nov 2011 09:58
Version 2.44 features the following amendments:
Altera EPM7xxxAE/B [FBGA100], improving of insertion test
Altera EPM7xxxS, bug fixed in verification routine
Atmel ATtiny25, additional ID byte check error fixed
Atmel AT90USB162 [MLF32] and AT90USB82 [MLF32], bug fixed
Atmel ATmega325P, ATmega3250P, ATmega165P, ID problem repaired for all types of packages and interfaces.
Freescale MC9S08AW48, AW60: ICGTRM (250kHz) memory map bug fixed
Hynix HYG0UGG0MF2 [FBGA107], bug fixed
Macronix MX29L8100G package information fixed
Microchip dsPIC30F6011A, erase procedure bug fixed
Microchip PIC16F884/887 [TQFP64], insertion test bug fixed
Microchip PIC18F8622, config. bits programming bug fixed
Spansion S29GL128P verification bug fixed
STM M93S46, reading Protect register bug fixed
Winbond W39V040C ID check procedure bug fixed
Altera EPM3xxxA, EPM7xxxAE/B, code optimization
Altera EPM7032S and EPM7064S, improving of POF file loading
AMD Am29F004, programming and unprotect algorithm improved
Atmel ATF750C in DIL24, adding of information about bypass capacitor
Atmel ATF1500, adding of new ID code, improving of read/verify actions, improving of programming parameters assignment
Atmel ATF1502xx/04xx/08xx, improving of programming parameters assignment
Catalyst CAT28C16A, read/verify improved
Freescale MC9S08AWxx, added another ICG calibration constant calculation
Hitachi HD64F216x device name changed to HD64F216xV
Macronix MX29LV160C, buffer size allocation (double size as necessary) bug fixed
Microchip PIC16F505, power-up procedure improved
Motorola MCM2814, device programming improved
NEC uPD70F3263, modification of communication
NEC uPD78F0034B, power-up procedure improved
Renesas M3087BFLGP, programming improved
Renesas M38027E8FP, modification of programming procedure
Spansion S29JL064H, ID check procedure improved, added non-Spansion mfr ID
SST SST39VF168x, programming speed increased
STM STR7xx series, ISP programming improvements
Texas Instrument (TMS) TMS320F2810, power-up sequence improved
Xilinx XC17xxx, adding of *.MCS file format support
Xilinx XC17xxx, modification of configuration bits storing and displaying of device checksum
Xilinx XC1736A, improving of programming parameters assignment
