New software - Version 3.27
Posted: 09 Nov 2016 16:46
Enabled ethernet connectivity for "ZIF sockets actuation control unit P1/08"
Fixed bug selftest procedure
Macronix MX66L51285G [SOP16] (Dual-Quad I/O), added support
Spansion S79FL256SxxMxxG0 [SO16] (Dual-Quad I/O), added support
Spansion S79FL512SxxMxxG0 [SO16] (Dual-Quad I/O), added support
Spansion S98FL256SxxMxxG0 [SO16] (Dual-Quad I/O), added support
