New software - Version 3.04
Postby Dataman (Daniel Smith) » 03 Mar 2014 14:11
Version 3.04 features the following amendments:
Fixed alignment of buttons Yes, No of Special options , Device operation options dialogs in Protected mode
New option for Custom generator serialization available. Option is: Skip check of serial number in command line "-N" parameter with value in record "T01:". Note: Suitable for custom generator applications, that ignore command line parameters -N
Fixed problem with incorrect characters of texts in dialog Serialization settings, especially for East-Asian languages (Japanese, and so on)
Fixed problem with long software delays during load project operation, when unicode language is used in software
For multiprogramming (PG4UWMC) is supported English language version only
In PG4UWMC fixed error messages about missing language files, when opening Settings dialog
3Dplus 3DPO64M08VS2299, improving of pgm. mode and read mode entering
Altera EPM7512B [FBGA256], adapter identification improved
Atmel/Adesto Techn. AT45DB642D (ISP)/AT45DB642D (ISP) (BSHG-1), Erase error report improved
Atmel AT32UC3Cx64C/128C/256C, Flash size corrected
Atmel ATA6612/13/14, insertion test modified
Atmel ATmega2561 (ISP-SPI), blank check modified
AUO AUO-L102.16, power-up sequence improved
Cypress CY8C20237 [QFN16], verify checksum modified
Fujitsu MB95560/570/580 Series, added programmable addresses 0xFFBE, 0xFFBF
Hitachi HD6473032F, device reading modified
Intel M29W256GHxxN [TSOP56], power-up sequence improved
NEC/Renesas uPD78F0524A, programming speed increased
Numonyx P30 family, POF file format added
Serial Flash Atmel/Adesto Techn. devices in SOIC8 200mil package, TurboMode is available
Serial Flash devices in SOIC8 150mil package supported by programming adapter DIL8W/SOIC8 ZIF 150mil SFlash-1a, TurboMode is available
Serial Flash devices in SOIC8 200mil package supported by programming adapter DIL8W/SOIC8 ZIF 200mil SFlash-1a, TurboMode is available
Silicon Laborat. C8051F35x, power-up sequence updated
Spansion S29AL032DxxTxx03 [TSOP48], power-up sequence and ID check improved
Spansion S29GL256PxxTxxR1 [TSOP56]x16, programming procedure modified
STMIcroelectronics PM6764, improving of device address polling
STMIcroelectronics PM6764, improving of pgm. mode entering
STMicroelectronics PM6764, programming procedure improved
STMicroelectronics STM32L15x family, USER byte default value fixed
STMicroelectronics STM8S208C6T, STM8S105K4T, configuration modified
TI (TMS) MSP430 devices with MSP430/MSP430X core and JTAG/4wireJTAG mode, power-up modified
TI (TMS) TM4C123BE6PM, some code improvements
AMD/Lattice/Vantis MACH111SP, ID check error bug fixed
Atmel ATmega164/A/PA (ISP-SPI), BOOTSZ fuse bits description bug fixed
Atmel ATmega256RFR2, programming and reading bug fixed
Berg Micro BG25Q32A, Erasing Security registers bug fixed
Dallas/Maxim DS28EC20, faulty request to set the programming parameters bug fixed
Fujitsu MB95F136 [SSOP30], insertion test bug fixed
Fujitsu/Spansion MB9AF11x/31xLPMC [LQFP64], insertion test bug fixed
Fujitsu/Spansion MB9AF13xLAPMC1 [LQFP64], insertion test bug fixed
Fujitsu/Spansion MB9AFB4xLAPMC [LQFP64], insertion test bug fixed
Giantec Semicond. GT24C32A [UDFN8], insertion test bug fixed
Hitachi HD6473032F, programming error bug fixed
Intel PC28F00BM29EWH, programming/reading bug fixed
Lattice M4A3-96/48, programming/reading bug fixed
Lattice M4A5-128/64 [PQFP100], ID check error fixed
Lattice MachXO2, changes according to the actual pgm. spec, programming DONE bit bug fixed, device ovecurrents resolved
Microchip PIC24FJ256GB210, set of Alternate Vref pin bug fixed
Microchip PIC24Fxxx, PIC32MXxxx in XBGA121 package, insertion test bug fixed
NAND flash devices, Access violation bug fixed if tolerant verify is disabled
NAND flash devices, Automatic YES! default settings for alternative adapters fixed
NEC/Renesas uPD78F182x, programming bug fixed
Silicon Laborat. C8051F930/931, memory size bug fixed
STMicroelectronics STM32L15x family, SWJDP communication problem fixed if HW IWDG is enabled in programmed device
STMicroelectronics STM32L15x family, Unexpected error 1 [IEC:1, D:85] on EEPROM programming fixed
TI (TMS) LM3S2608, nonvolatile registers bug fixed
TI (TMS) TM4C123xxx, verifying bug fixed
Xicor X2864A, programming bug fixed
