S4 how do you use it
Postby Guest » 14 Nov 2011 15:22
it's been a while since i have use the dataman. when you insert the eprom in the zif socket. what do you do then and what key pads to press?
i want to read the eprom
nickgurcha
Re: S4 how do you use it
Postby Dataman (Neil Parker) » 14 Nov 2011 15:22
Hi
You can start off by trying an auto ID on the chip. FUNC>PROM. If this doest detect the device then you will have to select it manually by processing PROM and then using the cursor keys to navigate. Once you have the chip selected you can read it into the S4 RAM, LOAD. You can then transfer the code in the RAM onto a blank device or send it to your PC via the serial cable.
If you need any further assistance please give me a ring on +44 (0)1300 322903
Is it possible to read/write 87LPC768 and MX10FMAXDPC 06FAX with S4 ? Which module
must be used ? tnx fer help
Klausi
Klausi,
Neither of those parts can be programmed on the S4. They can however be programmed on the D48UXP programmer. For full details and pricing please check out our website.
Return to “Dataman S4”
